werkende files Oscam
Hallo medeforummers,
wie helpt mij aan een werkende set OScam configuratie files voor de oranje smartcard van CD? Wil de kaart in de bovenste reader plaatsen.
Ik gebruik Oscam svn11086 voor de Solo 4K
Groet
Daf_driver
oeps foutje
??? Tonskidutsh
Op de feed kun je je Oscam binary downen, maar dat is dus zonder je configuratiefiles. Wellicht algmene maar niet specifiek voor CDS
Dit is mij Oscam log op di moment
  • 2017/05/19 20:29:15 00000000 [Emu] info: FFDecsa parallel mode = 32
  • 2017/05/19 20:29:15 2E59F2F8 r (reader) cds [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
  • 2017/05/19 20:29:15 2E59F2F8 r (reader) cds [internal] Reader sci internal, detected box type: vusolo4k
  • 2017/05/19 20:29:15 6EBA46BF r key file not found in: /usr/keys
  • 2017/05/19 20:29:15 6EBA46BF r key file not found in: /var/keys
  • 2017/05/19 20:29:15 6EBA46BF r (reader) emulator [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
  • 2017/05/19 20:29:15 21E40B7B h (webif) webif: decompressed 166185 bytes back into 397680 bytes
  • 2017/05/19 20:29:15 21E40B7B h (webif) HTTP Server running. ip=0.0.0.0 port=16200
  • 2017/05/19 20:29:16 6EBA46BF r (reader) emulator [emu] card detected
  • 2017/05/19 20:29:17 6EBA46BF r (reader) emulator [emu] found card system emu
  • 2017/05/19 20:29:17 6EBA46BF r (reader) emulator [emu] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
  • 2017/05/19 20:29:17 6EBA46BF r key file not found in: /usr/keys
  • 2017/05/19 20:29:17 6EBA46BF r key file not found in: /var/keys
  • 2017/05/19 20:29:20 00000000 s (main) init for all local cards done
  • 2017/05/19 20:29:20 00000000 s (anticasc) anti cascading disabled
  • 2017/05/19 20:29:20 1D7C2403 c (client) plain dvbapi-client granted (dvbapi, au=auto (2 reader))
  • 2017/05/19 20:29:20 1D7C2403 c (dvbapi) dvbapi channelcache loaded from /usr/keys/oscam.ccache
  • 2017/05/19 20:29:20 1D7C2403 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
  • 2017/05/19 20:29:21 1D7C2403 c (dvbapi) Demuxer 0 found 0 ECMpids and 3 STREAMpids in PMT
  • 2017/05/19 20:29:21 1D7C2403 c (dvbapi) Demuxer 0 serving srvid 6EF2 (FFFE@000000:6EF2 unknown) on adapter 0000 camask 0001 index 0000 pmtpid 0078
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1817 ECM_PID: 0711 PROVID: 00006A
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1818 ECM_PID: 0725 PROVID: 00006C
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 1819 ECM_PID: 0739 PROVID: 00006D
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0100 ECM_PID: 0711 PROVID: 00006A PBM: FFE000000000000 DATE: 19-5-2017
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0100 ECM_PID: 0725 PROVID: 00006C PBM: FFE000000000000 DATE: 19-5-2017
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 ecmpid 5 CAID: 0100 ECM_PID: 0739 PROVID: 00006D PBM: FFE000000000000 DATE: 19-5-2017
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 ecmpid 6 CAID: 0500 ECM_PID: 0C39 PROVID: 051900
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 skipped stream CAID: 0100 ECM_PID: 0711 PROVID: 00006A (Same as ECMPID 3)
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 skipped stream CAID: 0100 ECM_PID: 0725 PROVID: 00006C (Same as ECMPID 4)
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 skipped stream CAID: 0100 ECM_PID: 0739 PROVID: 00006D (Same as ECMPID 5)
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 skipped stream CAID: 0500 ECM_PID: 0C39 PROVID: 051900 (Same as ECMPID 6)
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 found 7 ECMpids and 5 STREAMpids in PMT
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 serving srvid 5225 (1817@00006A:5225 unknown) on adapter 0000 camask 0001 index 0000 pmtpid 0AA9
  • 2017/05/19 20:30:02 1D7C2403 c (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
  • 2017/05/19 20:30:06 1D7C2403 c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
  • 2017/05/19 20:31:21 1D7C2403 c (-) – Skipped 14 duplicated log lines –
  • 2017/05/19 20:32:21 1D7C2403 c (-) – Skipped 12 duplicated log lines –
doorspit even :
Ga ik doen, hoop dat ik er verder mee kom. Mijn CI werkt iig niet mee, of ik doe iets verkeerd. Maar dat is vers 2
Oscam butler gebruiken?
Ik heb ook solo 4k, werkt zonder problemen.
“2017/05/19 20:29:20 00000000 s (main) init for all local cards done”
Dat is alleen de emu reader. Verder wordt niet eens een poging gedaan om een smartcard te initialiseren. De configuratie is nog niet belangrijk want volgens oscam zit er nergens een kaart in een slot. Niet eens een kaart ondersteboven of een bankpas, maar gewoon ‘leeg’.
En de configuratie heeft alleen 1 reader voor /dev/sci0, die blijkbaar leeg is.
De tweede reader /dev/sci1 is niet geconfigureerd.
Als je een kaart in de ontvanger hebt, wellicht even het andere slot proberen?
[reader]
label = Canal_Digitaal
description = Bovenste cardreader
protocol = internal
device = /dev/sci1
autospeed = 0
caid = 0100
ecmwhitelist = 0100@00006A:64
ecmheaderwhitelist = 0100@00006A:800061006A00075C00,800061006A01075C00,803061006A00075C00,803061006A01075C00,810061006A00075C00,810061006A01075C00,813061006A00075C00,813061006A01075C00
detect = cd
mhz = 534
cardmhz = 369
ident = 0100:00006A
chid = 0100:000000,005C00
group = 1
emmcache = 1,1,15,0
blockemm-unknown = 1
blockemm-u = 1
blockemm-g = 1
auprovid = 00006A
ratelimitecm = 4
ratelimittime = 9000
srvidholdtime = 2000
En in de config map opslaan met bestandsnaam oscam.ratelimit:
#oscam.ratelimit
#NEW svn8869:08/25/2013
#ECMs ratelimit for OScam
#limit rate of ECMs allowed for an interval
#CAID:provider ID:service ID:ChID:ratelimitecm:ratelimitseconds:srvidholdseconds
#ratelimitecm = number of different SIDs in ECMs allowed for an interval
#ratelimitseconds = interval in seconds for ratelimit
#srvidholdseconds = extra time in seconds this service ID is kept in a slot before another servive ID can take its place
#example 0100:00002A:3A3A:4A00:0002:0010:0004
0100:00006A:13B0:5C00:0002:0009:0002 # Animal Planet
0100:00006A:13C8:5C00:0002:0009:0002 # CI crime & investigation
0100:00006A:17D1:5C00:0002:0009:0002 # Discovery Channel
0100:00006A:13C4:5C00:0002:0009:0002 # DiscoveryHD Showcase
0100:00006A:17B1:5C00:0002:0009:0002 # Disney Channel Benelux
0100:00006A:141B:5C00:0002:0009:0002 # duck TV DUT
0100:00006A:13CA:5C00:0002:0009:0002 # Eurosport 1 HD BE
0100:00006A:52E1:5C00:0002:0009:0002 # Eurosport 1HD NL
0100:00006A:5244:5C00:0002:0009:0002 # EuroSport2 BE
0100:00006A:1B94:5C00:0002:0009:0002 # EuroSport2 NL
0100:00006A:13C7:5C00:0002:0009:0002 # History HD DUT
0100:00006A:13CC:5C00:0002:0009:0002 # JimJam
0100:00006A:0306:5C00:0002:0009:0002 # Nat Geo Wild HD DUT
0100:00006A:51D5:5C00:0002:0009:0002 # TLC
0100:00006A:519F:5C00:0002:0009:0002 # Travel Channel HD
0100:00006A:51A2:5C00:0002:0009:0002 # Travel Channel HD NL
0100:00006A:7003:5C00:0002:0009:0002 # Comedy Central NL
0100:00006A:6FEF:5C00:0002:0009:0002 # MTV Dance
0100:00006A:6FEE:5C00:0002:0009:0002 # MTV Hits
0100:00006A:6FFF:5C00:0002:0009:0002 # MTV Music 24
0100:00006A:7002:5C00:0002:0009:0002 # MTV Nederland
0100:00006A:6FF3:5C00:0002:0009:0002 # MTV Rocks
0100:00006A:6FF7:5C00:0002:0009:0002 # Nick Jr..
0100:00006A:7007:5C00:0002:0009:0002 # Nickelodeon Nederland/Spike
0100:00006A:6FF0:5C00:0002:0009:0002 # VH1
0100:00006A:6FF1:5C00:0002:0009:0002 # VH1 Classic
kijk naar het device want bij mij is de bovenste cardreader sci0 en kaart zit met chip naar beneden erin.
Ceesv, ik kom er echt niet uit, heb nu bijna echt alles geprobeerd.
Kun je me niet jouw werkende configs sturen en jouw huidige binary?
Groet
Daf_driver
De OScam die je uit de feed hebt gedownload is prima, dus een binary heb je niet nodig, tenzij je echt de allerlaatste versie wilt.
Ik heb je de configuratie aangegeven voor de reader in oscam.server. Ev. is bij jou de bovenste cardreader /dec/sci0
Je zou ook nog:
cooldown = 30,600
moeten gebruiken, bij mij ging het beeld dan juist om de zoveel seconden stil staan, maar kan ook komen omdat de kaart nog in strafmodus stond.
Heb je in de instellingen van je VU+ misschien nog staan dat de CI-module gebruikt moet worden i.p.v. OScam?
Er zijn wel zenders die je met OScam niet kan decoderen en met de (juiste) CI-module wel.
Althans sommigen hier beweren dat het wel kan, maar vinden het belangrijk dat verder niemand weet hoe, of het is gewoon niet waar maar dat terzijde.
Kan je nog eens aangeven wat niet werkt en wat je in het log ziet zodra je de reader enabled waar de kaart in zit?
Of plaats je oscam.conf, oscam.server en oscam.user eens hier.
WAAR vind ik dat in Open Atv?
WAAR vind ik dat in Open Atv? Of de CI-module gebruikt moet worden?
**Hier mijn files : **
Log :
  • s (main) System name = Linux
  • 2017/05/21 17:00:19 00000000 s (main) Host name = vusolo4k
  • 2017/05/21 17:00:19 00000000 s (main) Release = 3.14.28-1.8
  • 2017/05/21 17:00:19 00000000 s (main) Version = #1 SMP Sat Mar 25 04:02:09 CET 2017
  • 2017/05/21 17:00:19 00000000 s (main) Machine = armv7l
  • 2017/05/21 17:00:19 00000000 s (main) Stb model = dm8000
  • 2017/05/21 17:00:19 00000000 s (main) Stb vumodel = vusolo4k
  • 2017/05/21 17:00:19 00000000 s (main) Stb boxtype = vusolo4k
  • 2017/05/21 17:00:19 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 3839
  • 2017/05/21 17:00:19 00000000 >> OSCam << cardserver log switched, version 1.20-unstable_svn, build r11384 (arm-linux-gnueabihf)
  • 2017/05/21 17:00:19 00000000 s (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
  • 2017/05/21 17:00:19 00000000 s (main) signal handling initialized
  • 2017/05/21 17:00:19 00000000 s (config) 912 provid’s loaded
  • 2017/05/21 17:00:19 00000000 s (config) 1471 service-id’s loaded in 5 ms
  • 2017/05/21 17:00:19 00000000 s (reader) CDS [internal] creating thread for device /dev/sci0
  • 2017/05/21 17:00:19 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
  • 2017/05/21 17:00:19 00000000 s (main) waiting for local card init
  • 2017/05/21 17:00:19 1AFE098C r (reader) CDS [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
  • 2017/05/21 17:00:19 1AFE098C r (reader) CDS [internal] Reader sci internal, detected box type: vusolo4k
  • 2017/05/21 17:00:19 2FF7DDB9 h (webif) webif: decompressed 184522 bytes back into 434792 bytes
  • 2017/05/21 17:00:19 2FF7DDB9 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
  • 2017/05/21 17:00:21 00000000 s (main) init for all local cards done
  • 2017/05/21 17:00:21 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 0 ms
  • 2017/05/21 17:00:21 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
  • 2017/05/21 17:00:21 00000000 s (anticasc) anti cascading disabled
  • 2017/05/21 17:00:21 2B05A6C8 c (client) plain dvbapi-client granted (dvbapi, au=auto (1 reader))
  • 2017/05/21 17:00:21 2B05A6C8 c (dvbapi) dvbapi channelcache loaded from /usr/keys/oscam.ccache
  • 2017/05/21 17:00:21 2B05A6C8 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
  • 2017/05/21 17:00:25 2B05A6C8 c (dvbapi) Demuxer 0 found 0 ECMpids and 3 STREAMpids in caPMT
  • 2017/05/21 17:00:25 2B05A6C8 c (dvbapi) Demuxer 0 found 0 ECMpids and 3 STREAMpids in PMT
Conf :
global]
nice = -1
disablelog = 0
#loghistorysize = 200
logfile = /var/keys/oscam.log
#usrfile = /tmp/oscamuserfile
[monitor]
#nocrypt = 127.0.0.1,192.168.0.0-192.168.255.255
#appendchaninfo = 1
[webif]
httpport = 8888
httpuser = solo4k
httppwd = solo4k
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
[dvbapi]
enabled = 1
au = 1
decodeforever = 1
boxtype = dreambox
user = dvbapi
for E2 set pmt_mode = 0
for Titan set pmt_mode = 4
pmt_mode = 0
Server :
[reader]
enable = 1
description = Set as Canal Digitaal
label = CDS
protocol = internal
device = /dev/sci0
emmcache = 1,1,2
detect = CD
ident = 0100:000000,00006A
auprovid = 00006A
provid = 00006A
group = 1
caid = 0100
mhz = 369
cardmhz = 369
User :
[account]
user = dvbapi
pwd = dvbapi
group = 1
au = 1
uniq = 0
Wordt zo langzamerhand knetter hiervan
Oeps Sjaak(k).
Ik moet mijn signatuur aanpassen, heb geen Topfiled meer, maar een VU+ Solo 4K met Open ATV 6.0.
Groet
Daf_driver
Ik gebruik VTi, daar zit alles in, incl.oscam butler.
Ben op dit moment in het buitenland, ver weg van mijn Solo, kan je eerst met een dag of 10 mijn files sturen.
Maar ik ga ervan uit dat het tegen die tijd al werkt, met de adviezen die je hier krijgt.
Sjaak(k),
OpenPli gebruik ik niet , Open ATV 6.0.
Groet
Daf_driver
Sorry, ik moet het antwoord schuldig blijven of het ergens anders staat in OpenATV dan in OpenPLi. Waar het in OpenPLi staat is hierboven al aangegeven, hopelijk is het hetzelfde.
Je hebt nog niet alle regels toegepast in je reader die ik aangaf, maar met jouw configuratie zou het al moeten werken.
Wat betreft je CI-module, er is in /etc/enigma2 een bestand ci0.xml wat aangemaakt wordt door de CommonInterfaceAssignment systeem plugin. Je moet deze dus wel geïnstalleerd hebben. Wat je daar precies moet instellen weet ik ook niet want ik gebruik geen CI-module. Ik heb die info van , kijk daar ook even, vooral als je OScom tesamen met een CI-module wilt gebruiken.
Maar als je de CI-module helemaal niet meer gebruikt, dan is verwijderen van de module m.i. genoeg om OScam vrij spel te geven, dat is dan nl. (als het goed is) de enige decoder die nog over is.
Kijk ook even in Menu>Instellingen>Softcam/CI en vergeef me als de menu-structuur in OpenATV anders is.
In je log zie ik maar kort iets over je reader ‘CDS’, t.w.:
En verder niks…(helaas).
Ofwel je kaart zit verkeerd in de cardreader (van de VU+, niet in de CI-module zeg ik maar even just in case), of zit in de verkeerde cardreader.
Wat ik hoop te zien is zoiets als dit:
(reader) CDS [seca] Restarting reader
(reader) CDS [seca] creating thread for device /dev/sci0
(reader) CDS [seca] Reader initialized (device=/dev/sci0, detect=cd, mhz=534, cardmhz=369)
(reader) CDS [seca] Reader sci internal, detected box type: vusolo4k
(reader) CDS [seca] card detected
(reader) CDS [internal] ATR: 3B F7 11 00 01 40 96 70 70 0A 0E 6C B6 D6
(reader) CDS [internal] Init card protocol T0, FI=1, F=372, D=1, N=1
(reader) CDS [internal] Calculated work ETU is 69.66 us reader mhz = 534
(reader) CDS [internal] ATR Fsmax is 5 MHz, clocking card to 5.34 (specified in reader->mhz)
(reader) CDS [internal] detect seca/nagra tunneled card
(reader) CDS [internal] Nagra layer found
(reader) CDS [internal] Rom revision: DNASP400 RevI4A
(reader) CDS [internal] type: SECA, caid: 0100, serial: #########, card: Mediaguard v10.0
(reader) CDS [internal] Maturity level [F]=no age limit
(reader) CDS [internal] Using PIN 0000!
(reader) CDS [internal] Parental lock disabled
(reader) CDS [internal] found card system seca
(reader) CDS [seca] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
(reader) CDS [seca] Request provider 1
(reader) CDS [seca] provider 1: 0000, valid: 1, name: MANAGEMENT, expiry date: 2017/07/18
(reader) CDS [seca] SA: ########
(reader) CDS [seca] PBM for provider 1: *************
(reader) CDS [seca] Request provider 2
(reader) CDS [seca] provider 2: 006A, valid: 1, name: CANAL DIGITAAL, expiry date: 2017/07/19
(reader) CDS [seca] PBM for provider 2: ****************
Of staat misschien verder in je log?
je laatste deel verwacht ik dus ook, maar dat komt niet, de kaart wordt niet gezien lijkt t op.
Heb m al eens in de onderste sleuf gehad, ook boven, beide zijden van de kaart ook eens omgedraaid.
Schiet mij maar echt lek! Heb mn oude Topfield ff aangesloten en de kaart in mn smargo geplempt, voila, beeld.
Ik geef t helemaal op
Ik plaats nog ff mn oscam.log na het op NPO1 gezet te hebben
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1817 ECM_PID: 0711 PROVID: 00006A
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1818 ECM_PID: 0725 PROVID: 00006C
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 1819 ECM_PID: 0739 PROVID: 00006D
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0100 ECM_PID: 0711 PROVID: 00006A PBM: FFE000000000000 DATE: 21-5-2017
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0100 ECM_PID: 0725 PROVID: 00006C PBM: FFE000000000000 DATE: 21-5-2017
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 5 CAID: 0100 ECM_PID: 0739 PROVID: 00006D PBM: FFE000000000000 DATE: 21-5-2017
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 6 CAID: 0500 ECM_PID: 0C39 PROVID: 051900
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 found 7 ECMpids and 5 STREAMpids in caPMT
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
  • 2017/05/21 18:24:49 00000000 >> OSCam << cardserver log switched, version 1.20-unstable_svn, build r11384 (arm-linux-gnueabihf)
  • 2017/05/21 18:24:49 7F3C7C30 c (dvbapi) Demuxer 0 found 7 ECMpids and 5 STREAMpids in PMT
  • 2017/05/21 18:24:54 7F3C7C30 c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
  • 2017/05/21 18:25:14 7F3C7C30 c (-) – Skipped 4 duplicated log lines –
  • 2017/05/21 18:25:14 7F3C7C30 c (dvbapi) Demuxer 0 stop descrambling program number 5225 (1817@00006A:5225 unknown)
  • 2017/05/21 18:25:20 7F3C7C30 c (dvbapi) Demuxer 0 found 0 ECMpids and 3 STREAMpids in caPMT
  • 2017/05/21 18:25:20 7F3C7C30 c (dvbapi) Demuxer 0 found 0 ECMpids and 3 STREAMpids in PMT
  • 2017/05/21 19:17:56 7F3C7C30 c (dvbapi) Demuxer 0 stop descrambling program number 6EF2 (FFFE@FFFFFE:6EF2 unknown)
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1817 ECM_PID: 0711 PROVID: 00006A
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1818 ECM_PID: 0725 PROVID: 00006C
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 1819 ECM_PID: 0739 PROVID: 00006D
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0100 ECM_PID: 0711 PROVID: 00006A PBM: FFE000000000000 DATE: 21-5-2017
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0100 ECM_PID: 0725 PROVID: 00006C PBM: FFE000000000000 DATE: 21-5-2017
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 5 CAID: 0100 ECM_PID: 0739 PROVID: 00006D PBM: FFE000000000000 DATE: 21-5-2017
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 ecmpid 6 CAID: 0500 ECM_PID: 0C39 PROVID: 051900
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 found 7 ECMpids and 5 STREAMpids in caPMT
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
  • 2017/05/21 19:18:01 7F3C7C30 c (dvbapi) Demuxer 0 found 7 ECMpids and 5 STREAMpids in PMT
  • 2017/05/21 19:18:06 7F3C7C30 c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
  • 2017/05/21 19:18:16 7F3C7C30 c (-) – Skipped 1 duplicated log lines –
Zie het rode deel
