Een nieuwe versie van NewCS is uitgebracht, met veel veranderingen/fixes & met volledige USB Infinity support.
Changelog
* Fixed ECM/EMM Cache, should now be OK again. (strange noone noticed this one long time ago?!)
* Added support for DM800 Sci. (needs more testing though..)
* Completely rewritten Chameleon, now called Chameleon2.
* Removed support for the Feynman protocol as its wasnt a success, and we dont have time to maintain it.
* Fixed bug to address comports higher then com9 on win32.
* Fixed EMM bug on irdeto.
* Fixed bug where user would be disabled when changing the users through WEB-console.
* Added provider 0106 and 0907 in nagra2.
* Added support for the QNAP NAS’s.
* Added support for the Freetz routers.
* Now using Kamikaze env. for compiling OpenWRT binaries.
* Fixed -march=i386 on i686, should now be i386 compatible.
* Added boxdetect for more platforms. If your box isnt detected ok, please post your /proc/cpuinfo.
* Fixed WEB-console on win32, added it on all archs.
* Added backup of configfile before writing to it. (/tmp for linux, and C:\temp for win32)
* Many other bugfixes and cosmetic fixes.
