Wordt verwacht in December .
4K UHD box from Edision with DVB-S2x, DVB-T2, multistream, blindscan, native T2-MI and many more…
Housing in ALU Handcrafted remote control with ALU Finish
newest 64 bit Linux 4.19 thus the first E2 Enigma2 Broadcom box on the market.
•2GB high speed DDR-4 Ram
•8GB EMMC Flash
•optional up to 12 SATIP tuners (vtuner)
•multiBoot
•openGL support
•HBBTV
•KODI
•QT WEBKit Browser
•Blindscan with multistream support
•Media playback up to 2160P H265 as well as H264
•PIP
•WIFI 2.4 and 5 GHZ
•HDR Force for old UHD TV
•HLG / HDR10 support
•Bluetooth HID support
•High quality drivers
•excellent support
Technical specifications:
• 4K UHD set-top box
• Linux Operating System
• Dual core ARM 1.5 GHz
• H.265 HEVC decoding support
• FLASH 8GB eMMC / RAM 2GB DDR4 2400Mhz
• 1 x DVB-S2X tuner
• 1 x DVB-T2 / C tuner
• Multi Stream Support
• Blind Scan Support
• 4K UHD Multimedia Player
• Smart Card Interface
• Dual Band 2x2 Wi-Fi 802.11ac 5G / 2.4G with MU-MIMO
• 2 x Pluggable Wi-Fi Antennas
• Bluetooth embedded 2.1 / 3.0 / 4.0
• Solid 10 / 100Mbps Ethernet Network Interface
• Live streaming through the Home Network
• Picture in Picture (PIP)
• Web browsing support
• Expandable add-ons and plug-ins
Free Internet Streaming TV and Radio
• Universal Remote Control 2in1
• Aluminum Case 180mm
Richtprijs zou +/- 150 euro bedragen.
Zal deze ontvanger ook 4:2:2 feeds kunnen weergeven?
Mooi , vroeger dan verwacht.
Prijs valt ook best mee…
HDMI 1.4 wat een teleurstelling
, binnen enkele maanden komt HDMI versie 2.1 uit.
Ook geen CI slot, dus alleen te gebruiken als FTA ontvanger.
specs kloppen niet op de afbeelding van C S
dit zijn de OS MIO 4K S2X/T2/C specificaties in het Engels:
EDISION OS MIO 4K S2X + T2/C, is the new E2 LINUX 4Κ UHD, DVB-S2X combo receiver in the E2 LINUX range of EDISION receivers. It features 4K UHD resolution and has Multi Stream T2MI Tuner & Blindscan. It is equipped with a variety of the most advanced features in order to provide you with an exciting use of all its top characteristics, all in a compact and slim design! It is available in an elegant aluminum box, in 2 color choices, with features that include: E2 Linux operational system, DVB-S2X and DVB-T2/C Τuners, 4K UHD resolution, Multi Stream T2MI Tuner, Blindscan, Web browser and HbbTV support, Dual Core ARM at 1.5 GHz processor, 8GB eMMC/RAM 2GB DDR4 2400Mhz flash memory, WiFi with two (2) external, detachable wifi antennas (included), Bluetooth on Board, 4K UHD Multimedia Player plus the exceptional and ergonomical aluminum IR remote control UNIVERSAL 2-in-1, in the same color as the receiver! All these combined with the overall EDISION quality and professional support, make it a superior option for you to enjoy!
Technical features:
- Type: 4K UHD E2 Linux Combo Reivever DVB-S2X + DVB-T2/C with Multi Stream Support
- 1 x Tuner DVB-S2X
- 1 x Tuner DVB-T2/C
- Decoding: H.265/HEVC decoding support (covered by patents listed at patentlist.hevcadvance.com)
- Multi Stream T2MI & Blind Scan support
- Linux operational system
- Processor: Dual Core ARM 1.5 GHz
- FLASH 8GB eMMC/RAM 2GB DDR4 2400Mhz
- 4K UHD Multimedia Player
- Web Browser & HbbTV support
- Free Internet Streaming TV and Radio
- Dual Band 2x2 Wi-Fi 802.11ac 5G/2.4G with MU-MIMO
- 2 x Pluggable Wi-Fi Antennas
- Bluetooth: embedded 2.1/3.0/4.0
- Unlimited channel memory
- Hyper-sensitive tyner for receiving even the weak-signal channels
- 1 x Smartcard reader
- 10/100 Mbps Ethernet interface
- 2 x USB2.0 ports
- 1 x HDMI 1.4a Connection
- 1 x jack to RS232
- 1 x jack to IR
- 1 x S/PDIF
- Channel switch in less than 1 second
- Extensive ΕPG and programmed viewing via EPG
- Expandable Add-Ons & Plug-Ins
- Supports Bouquet list
- Multilingual OSD, Skin - support
- Channel search: Fully automatic/Manual
- Time Shift function and Multi Timers
- Supports Teletext & and OSD and VBI subtitles
- Compatible with DiSEqC 1.0, 1,1 ,1.2 and 1.3 (USALS)
- Supports SCR / CSS (EN50494 & EN50607)
- Power consumption less than 0.5 Watt, in low-power stand-by mode
Front Panel:
- Display: LED (Standby, Recording)
- Display Buttons: Power, Channel -/+
Back Panel:
- Input Sat-IF: 1x F-type
- Input RF: 1x IEC-type
- Connection TV: 1x HDMI
- Video output: 1x HDMI
- Audio output: Standard optical (S/PDIF)
- 2 x WiFi Antennas
- 1 x Smartcard slot
- 1 x Ethernet plug
- 1 x jack to RS232
- 1 x jack to IR
- 1 x DC in (for the external PSU)
Package contains:
- Universal Remote Control 2in1
- External PSU 12v
- Jack to IR cable
- USB extension cable
- 2 x Wi-Fi Antennas
- 2 x “ΑΑΑ” batteries
- Start Guide EN/DE/GR
General:
- Case: Aluminum
- Dimensions: (W x H x D): 180x40x140 (mm)
- Weight: 0,7 kg
- Color: Grey
- Warranty: 2 years
https://www.edision.gr/en/detail/os-mio-4k-s2x-t2-c-grey
6 uur geleden zei patje7of9:
HDMI 1.4 a
https://nl.wikipedia.org/wiki/High-definition_multimedia_interface
lijkt mij een leuk kassie voor de normale gebruiker
en de HDMI versie is d’rom niet important, dat wordt het pas bij afspelen van mediabestanden via een AV receiver
je TV is backward compatible qua HDMI versie, misschien mis je dan echter het HDMI-CEC tussen edison en TV
@satmaat
Idd. mijn afbeelding met de specs zijn verkeerd en zijn voor een nino / + / pro. Sorry hiervoor.
Voor de mio 1500 Mhz arm64 uhd 4k (3840x2160p) is de prijs : 164,90 €
@ patje7of9
HDMI 1.4a is heus geen teleurstelling , alles hangt af waarvoor je deze ontvanger gebruikt. Ikzelf ben een hobbyist en feedhunter en die ontvanger zal dienen voor een Iiyama G-Master Gold Phoenix GB2888UHSU van 28 inch voorzien van een mini DisplayPort.
Deze ontvanger is een vervanger voor mijn DM800 HD PVR die echt aan vervanging toe is. Voor het feedhunten gebruik ik ook nog mijn Technomate TM-5402 HD M3 CI+ en voor de ontvangst van de C-Band een Dr.HD F15 , alles op hetzelfde rek . Ik heb ook een Edison OS mini en de blindscanning van deze is heel adequaat en snel.
Een CI+ slot is niet nodig , is toch een linux ontvanger en daar draai je toch CCcam,OScam,enz… op , met een handige configuratie heb je toch de betaalzenders binnen ?
Ik heb meer behoefte aan een moderne TV met een CI+ slot waarop ik mijn Deltam Twin module gebruik , heb er alle zenders van telenet op ( uitgezonderd de betaalzenders ) en nog veel meer mogelijkheden met de laatste software.
_- HD+ HD03/HD03a/HD04 smartcards support
- MaxTV CAK7 smartcards support
- CSat smartcards SECA 3 pairing on HD channels (nano 01)
- Fransat smartcards Viaccess 5/6
- CSat smartcards Viaccess 5/6
- TéléSAT smartcards SECA 3 pairing (nano 01)
- Canal Digitaal NL smartcards SECA 3 pairing (nano 01)
- TV Vlaanderen smartcards SECA 3 pairing (nano 01)
- CanalSat smartcards support (Viaccess nano E0)
- BiS-TV smartcards support (Viaccess nano E0)
- OrangeFR smartcards support (Viaccess nano E0)
- Skylink smartcards support Irdeto and ICE
- SRG emulator support_
Most important emu-provider:
SRG SSR (13.0°E)
Mezzo (13.0°E)
Bovendien beschikt deze ontvanger over een BCM72604 processor , dezelfde als die gebruikt wordt in een VU+ Zero 4K .
De processor werkt ook met de android software.( Arris Zx4430 UHD device ).
Ben benieuwd vanaf wanneer hij op de markt komt.
Citaat
Op 8-12-2018 om 16:18 zei patje7of9:
Features from Edision HDMI 2.0a
https://edision.de/produkte/linux-re…2x-t2-c-white/
Vanaf heden te bestellen in Nederland en Duitsland.
Nederland : 169 euro ( gratis verzending)
Duitsland : 159 euro ( 12 euro verzending )
ps : voorzien van HDMI 2.0a.
De specs zijn niet (meer) up to date wat betreft de Seca3 kaarten. CWOE (nano 01) wordt niet meer ingezet. Is vervangen door de native Nagra… Dus dat is geen verkoop argument meer..
Citaat
Ik heb al jaren geen nood aan een smart card interface of CI module. Gewoon mijn config aanpassen met kladblok in CCcam,OScam,… en ik zie alles wat ik wil.
Voor mij als feedhunter de ideale linux ontvanger , zeer snelle blindscanfunctie ( en in de frequentiestappen die ik wil ) + multistream / T2 + UHD… wat wil je meer.
2 uur geleden zei Crazy Sat:
Wat ik nog meer van een satellietontvanger zou willen is het ontvangst van NS3 & NS4 signalen maar dat zal waarschijnlijk nooit komen want Novelsat heeft een patent op deze uitzendnormen.
Op 22-12-2018 om 13:58 zei Crazy Sat:
Heb jij deze al gekocht?
Of heb je deze als feedhunter (blindscan) al kunnen testen ?
Citaat
Die ligt straks als “cadeaubon” onder de kerstboom , gift van mijn kinderen. Hopelijk wordt deze cadeaubon snel verzilverd in een bestelling.
16 uur geleden zei Crazy Sat:
Dat is een mooi kerstcadeau
Als deze ontvanger over enige tijd binnen is mogen we dan je ervaringen lezenr, als feedhunter ?
Citaat
Natuurlijk , maar de eerste ervaringen zullen pas in de loop van januari zijn.
