DreamTV Mini Ultra HD
New DreamTV Mini Ultra HD komt eind deze week op de markt.
Prijs zal rond de 95,00 Euro zijn.
Technical Details:
Android 9.0
DreamTV App (exclusivly for DreamTV Mini Ultra HD )
4k 60fps
CPU 4 core
Ram 2GB
Flash 16GB
GPU Mali-G31MP2
Wifi 2,4G/5G MIMO
H2.64/H2.65
HDMI
100Mbit Lan
optical output
Mini USB Service Port
SD Cardreader
1x USB 3.0
1x USB 2.0
BT 4,2
size: 132 x 80 x 25 (BxTxH) Weight ca. 100gramm.
Alleen ‘heet’ dit ding DreamTV, het heeft absoluut niets te maken met het bedrijf Dreambox.
ok, en waarom moet ik dit kopen? Unieke eigenschappen zijn…
4 uren geleden, Mimisiku zei:
Hmm toch wel als je dit leest.
The DreamTV Mini UltraHD IPTV media player from Dreambox is Android 9.0 based. This IPTV player has a powerfull 4 Core CPU and 2GB RAM. The DreamTV Mini UltraHD media player has a built-in WiFi 2.4G/5G MIMO connection and a 100 Mbit ethernet port. A SD card reader is also integrated in this media player. The DreamTV Mini Ultra HD IPTV set-top box gets its signal via internet, so a satellite antenna is not required!
4K Ultra-HD
The DreamTV Mini Ultra HD IPTV medias player supports 4K Ultra-HD/HDR 10. To enjoy 4K image quality also a 4K TV needs to be connected! Within a few steps you can create your own Favourite lists, with your own favourite channels. With this DreamTV IPTV receiver you can set up multiple stream sources, and include ‘live’ and video-on-demand (VOD) channels to your own platform.
Applications & Games
This Dreambox IPTV set-top box turns your TV into a SmartTV; via the Android interface all kind of APP’s and games can be installed. The DreamTV Mini ultra HD IPTV receiver is based on the DreamTV App; this App is exclusively designed for this IPTV set-top box and assures an user-friendly control of the box.
Many connection options
The DreamtV Mini Ultra HD IPTV has lots of connection options for external devices. Next to a built-in Bluetooth 4.2 connection, also an optical connection is available for the best sound quality. Also the possibility to connect an external hard drive and / or USB stick is possible via the available USB 2.0 or USB 3.0 port. Updating of the box is easy via the available service port.
Technical parameters DreamTV Mini Ultra HD IPTV media player
Supported protocols / portals
  • M3U-lists
  • Stalker
  • Xstream Codes
  • Enigma 2
  • And more…
General
  • 4k 60 FPS
  • CPU 4 core
  • Flash 16GB
  • GPU Mali-G31MP2
  • WiFi 2,4G/5G MIMO
  • H2.64/H2.65
  • HDMI
  • 100Mbit Lan
  • Optical input
  • Mini USB Service Port
  • SD card reader
  • 1x USB 3.0
  • 1x USB 2.0
  • Bluetooth 4.2
  • Android 9.0
  • Quad-Core Amlogic S905X2 Processor
  • 2GB RAM
Content packaging:
  • Dreambox ( DreamTV) Mini Ultra HD IPTV media player
  • RC 20 remote control
  • Twee AAA batteries
  • Power adapter (12V)
  • HDMI cable
Benieuwd of je de hdd van je dreambox in de woonkamer kunt mounten!
Op 13-4-2023 om 17:53, wortellica zei:
Ja dus …
Kan hier openpli op draaien of kun je die verbinden met een andere E2 box als client.?
Dat laatste, verbinden met een andere box als client!
Het ding eens bekeken.. Het is in elk geval geen ‘echte’ Dreambox telg. Officiële Dreamboxen komen van Leontech in Hong Kong. Deze komt van een andere firma. Het draait Android en geen Enigma2. Voorts kan ik verder ook niets vinden qua (firmware) support voor dit bakje. Het is gewoon ëén van de vele Android boxjes met een verouderde Android 9. Ze hebben gewoon het design van Dreambox gekopieerd en gebruiken de naam ‘Dreambox’ om zo hun verkoop te stimuleren. Eigenlijk niets nieuws onder de zon… Mocht hij wel een echte Dreambox telg zijn geweest dan zou ik hem alleen kopen om de serie compleet te hebben… Nu laat ik hem lekker links liggen. Hij is overigens bij de meeste grotere dealers al niet meer te krijgen. Ook een aanwijzing dat het om een eendagsvlieg gaat….
https://board.dreamtv.app/
Even bekeken..Daar schijnt sinds 2020 ook niets meer te gebeuren…. Vooral geen reacties van de moderators, geen updates… Blinkt niet uit qua geloofwaardigheid…
10 uren geleden, Mimisiku zei:
Toch zeggen meer dan tig bronnen dat het van Dreambox is en uiteraard draait er Android op anders bijna geen IPTV mogelijkheden, dan lijkt me het mij ook logish dat het apparaat uit een andere fabriek moet komen. Daarnaast bespaar je de moeite want zo goed is deze mediabox helemaal niet en is voor zijn daden zwaar aan de prijs, dat zal misschien komen door al die extra aansluitingen op de box zelf die bij veel andere boxen ontbreken.
Zit ook de afstandsbediening van dream bij!
de Vu+ Ya Go Pro als IPTV kassie heeft Android 10 erin en werd voor afgaand aan die Dreamtv mini ultra hd uitgebracht, niet dat het een heel groot verschil maakt net geen 5 € duurder.
19 uren geleden, Mimisiku zei:
daar staat op enkele Nederlandse websites andere informatie over
ik las dat niet alle apps erop (beiden) werken
1 uur geleden, wortellica zei:
Dat zegt helemaal niets! In China wordt alles gecloned. Een malletje pikken/clonen is daar zo geregeld. De box komt uit een andere fabriek. Het kan zelfs zijn dat ze het onderling aan elkaar ‘leveren’. Het is en blijft géén Dreambox. Op de officiële Dreambox site vind je hem niet. Ook niet op www.dreamboxupdate.com en niet op het Dreambox forum… Ze mogen hem 100 keer ‘dreambox’ noemen; hij is het gewoon niet…
Op hún forum staat de echte leverancier vermeld. Een full image recovery geven ze niet uit.. Het is allemaal errug wazig…
Leuk apparaatje voor de slaapkamer, voldoet prima!
12 uren geleden, Mimisiku zei:
Net als bij https://www.dreambox.de/
Niks nakkes nada, dus ze lijken wel heel erg op elkaar…
Heb toch maar besloten om zo’n bakje voor een vriendin te kopen… Kan er echter niks mee aanvangen! WiFi verbinding maakt ie niet (ondanks correct wachtwoord). Herkent zogenaamd de SID niet. Ethernet werkt wel. Niks te installeren qua legale Apps. Canal Digitaal, TV-Vlaanderen, Ziggo Go installeert wel, maar werken geen van alle! Komt met melding ‘Downloaden via Google Play’. Maar Google Play is nergens te vinden! Systeem opgewaardeerd naar laatste versie… MAC adres van box is anders als wordt aangegeven tijdens installatie…..
18 uren geleden, Mimisiku zei:
Maandag ochtend model!
20 uren geleden, wortellica zei:
Nee, dat geloof ik niet. Het zit hem in de revisie. De rev 1 draait op Android 9 en heeft de Google Play Store en daar werkt het wel op. De rev 2 (die hier klaarblijkelijk staat) heeft Android 11 en Aptoide en daar werkt het dus niet.
De XCPlayer werkt op de laatste prima (als je via een server wil kijken). Hij doet ook Enigma2 streams, Stalker Portal, Ministra en M3U Playlist…
