Hoi heeft iemand het ook gemerkt dat er zender niet open gaan met kaart en andere FTA zijn
10:45 tot en met nu 11:30
of is er iets anders met mijn kaart aan de hand
2026/10/21 11:51:47 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 5081
2026/10/21 11:51:47 00000000 s (config) services reloaded: 0 services freed, 60 services loaded, rejected 0
2026/10/21 11:51:47 00000000 s (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2026/10/21 11:51:47 00000000 s (main) signal handling initialized
2026/10/21 11:51:47 00000000 s (config) 15 provid's loaded
2026/10/21 11:51:47 00000000 s (config) 318 service-id's loaded in 2 ms
2026/10/21 11:51:47 00000000 s (signing) Binary = Verifying file /usr/bin/oscam-tj-update...
2026/10/21 11:51:47 00000000 s (signing) Signature = Valid - Binary's signature was successfully verified using the built-in Public Key
2026/10/21 11:51:47 00000000 s (signing) Certificate = Trusted Self Signed Certificate, valid until 31.05.2027 11:28:40
2026/10/21 11:51:47 00000000 s (led) LED support is not active. Can't detect machine type.
2026/10/21 11:51:47 00000000 s (net) cs378x: initialized (fd=3, port=12005)
2026/10/21 11:51:47 00000000 s (reader) ZiggoKaart [internal] creating thread for device /dev/sci0
2026/10/21 11:51:47 00000000 s (main) waiting for local card init
2026/10/21 11:51:47 5429428B r (reader) ZiggoKaart [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2026/10/21 11:51:47 5429428B r (reader) ZiggoKaart [internal] Reader sci internal, detected box type: vuplus
2026/10/21 11:51:47 16EE6ADA h (webif) webif: decompressed 173811 bytes back into 440512 bytes
2026/10/21 11:51:47 16EE6ADA h (webif) HTTP Server running. ip=:: port=8081 (no SSL)
2026/10/21 12:47:30 00000000 s (main) init for all local cards done
2026/10/21 12:47:30 00000000 s (emmcache) loaded 0 emmcache records from /etc/tuxbox/config/oscam.emmcache in 0 ms
2026/10/21 12:47:30 00000000 s (emmcache) loaded 0 emmstat records from /etc/tuxbox/config/oscam.emmstat in 0 ms
2026/10/21 12:47:30 00000000 s (anticasc) anti cascading disabled
2026/10/21 12:47:30 1B4D3C5E c (client) plain dvbapi-client granted (dvbapiau, au=auto (2 reader))
2026/10/21 12:47:30 1B4D3C5E c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam.ccache
2026/10/21 12:47:30 1B4D3C5E c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum number of filters is 64 (oscam limit is 64)
2026/10/21 12:47:30 1B4D3C5E c (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 16
2026/10/21 12:47:41 5429428B r (reader) ZiggoKaart [internal] card detected
2026/10/21 12:47:47 5429428B r (reader) ZiggoKaart [internal] WARNING: Total ATR characters received is: 20 instead of expected 22
2026/10/21 12:47:47 5429428B r (reader) ZiggoKaart [internal] ATR: 3B 9F 7B 8F 6D 52 44 5D 54 4F 20 41 3D 53 FB 56 37 2E 30 9F
2026/10/21 12:48:07 5429428B r (reader) ZiggoKaart [internal] Warning: F=0 is invalid, forcing FI=1
2026/10/21 12:48:07 5429428B r (reader) ZiggoKaart [internal] Warning: D=0 is invalid, forcing D=1
2026/10/21 12:48:07 5429428B r (reader) ZiggoKaart [internal] ERROR: Parse_ATR returned error
2026/10/21 12:48:07 5429428B r (reader) ZiggoKaart [internal] Error activating card.
2026/10/21 12:48:43 5429428B r (reader) ZiggoKaart [internal] ERROR: no characters found in ATR!
2026/10/21 12:48:43 5429428B r (reader) ZiggoKaart [internal] Deactivating card
2026/10/21 12:48:58 5429428B r (reader) ZiggoKaart [internal] Read ATR fail, attempt 1/7 fs = 9
2026/10/21 12:49:19 5429428B r (reader) ZiggoKaart [internal] ERROR: no characters found in ATR!
2026/10/21 12:49:19 5429428B r (reader) ZiggoKaart [internal] Deactivating card
2026/10/21 12:49:19 5429428B r (reader) ZiggoKaart [internal] Read ATR fail, attempt 2/7 fs = 8
2026/10/21 12:49:51 5429428B r (reader) ZiggoKaart [internal] ERROR: no characters found in ATR!
2026/10/21 12:49:51 5429428B r (reader) ZiggoKaart [internal] Deactivating card
