Ik kreeg vrijdag van de IT mensen van mijn firma de volgende email:
Please be advised that if you receive an email with the following subject
line(s) or body text (see examples below), it is a virus. It can cause extensive
damage not only to your system but also to our local area network.
Norton Anti Virus, on our mail servers, will most likely remove the infected
file. However, as always please use caution when opening emails/attachments from
an unknown source.
See this Symantec site link for more detail on this virus or how to remove it
once you are infected. http://www.symantec.com/avcenter/venc/data/w32.sircam.worm@mm.html
Please contact your local I.S. department in case you need assistance.
Regards,
Client Services
Examples:
This worm arrives as an email message with the following content:
Subject: The subject of the email will be random, and will be the same as the
file name of the attachment in the email.
Message: The message body will be semi-random, but will always contain one of
the following two lines (either English or Spanish) as the first and last
sentences of the message.
Spanish Version:
First line: Hola como estas ?
Last line: Nos vemos pronto, gracias.
English Version:
First line: Hi! How are you?
Last line: See you later. Thanks
Between these two sentences, some of the following text may appear:
Spanish Version:
Te mando este archivo para que me des tu punto de vista
Espero me puedas ayudar con el archivo que te mando
Espero te guste este archivo que te mando
Este es el archivo con la informaci=n que me pediste
English Version:
I send you this file in order to have your advice
I hope you can help me with this file that I send
I hope you like the file that I sendo you
This is the file with the information that you ask for.
Ik hoop dat ik jullie hiermee geholpen heb.
Groet
