heb ik net geprobeerd hij geeft aan flash erase en dan doet die het zelfde weer.
heb het volgende nog even geprobeerd :
console=ttyS0,115200 root=/dev/mtdblock/0
dan geeft die aan :
[eTimerManager] wait for clock update..
[eTimerManager] wait for clock updatestorage
[eTimerManager] wait for clock updategistered.
[eTimerManager] wait for clock updaten for all mice
[eTimerManager] wait for clock update.0
ibm-iic: using
[eTimerManager] wait for clock updateyour board specific setup
i2c-dev.
Dreambox DM7000BM IIC’ as mino
loaded at: 00500000 006161F8
i2c-core.o: adapter
relocated to: 00400000 005161F8
[eTimerMan
board data at: 00513128 00513168ing standard (100 kHz) mode
relocated to: 00404BEC 00404C2Cd
ibm-iic: using compatibility v
zimage at: 00405128 0051283E specific setup
avail ram: 00517000 02000000r] wait for clock update
i2c
Linux/PPC load: console=ttyS0,115200 roger] wait for
IP: ro
zone(0): 8192 pages.e of 512 buckets, 4K
zone(1): 0 pages.ager] wait for cl
zone(2): 0 pages.
TCP: Hash ta
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock/0
[eTimerManag
NET4: Unix domain socket
Console: colour dummy device 80x25
Calibrating delay loop… 251.49 BogoMIPSstem) readonly.r] wait for clock update04
Memory: 29764k available (1920k kernel code, 596k data, 92k init, 0k highmem)8
[eTimer
Freeing unused kernel memory: 92k in
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)en an initial console.
avail ram: 005
[eTimerManager] w
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
Content-Type: text/plain wait for clock updateTT
[ENIGM
devfs: boot_options: 0x1ct
JFFS2 version 2.1. © 2001 Red Hat, Inc., designed by Axis Communications AB.n Timezone Setup
[eTime
creating new f
i2c-core.o: i2c core module00 .. 00ffffffe Se
[eTimerM
i2c-dev.o: i2c /dev entries driver modulecreating
creating new font color c
i2c-core.o: driver i2c-dev dummy driver registered.
c
i2c-proc.o version 2.6.1 (20010825)25b7395 .. 00ffffff clock update
pty: 256 Unix98 ptys configured[F
[eTimerManag
[eTimerManager]
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enfor clock updateeTimerManager] wait for
[eTimerManag
abledpdate
ttyS00 at 0xe0040000 (irq = 20) is a 16550ArManager] wait for clock updateeTimerManage
ttyS01 at 0xe0000000 (irq = 21)
dreambox: flash mapping: 800000 at 7f800000for clock update
disable flash VPPManager] wait for
Creating 6 MTD partitions on “DreamBOX rev3+”:005
0x00000000-0x00600000 : "DreamBOX cramfs"nager] wait for clock updatehfs
0x00600000-0x007c0000 : "DreamBOX jffs2"wait for clock updateompressing Linux…
0x007c0000-0x00800000 : "DreamBOX OpenBIOS"clock update
Welcome t
0x00000000-0x007c0000 : “DreamBOX (w/o bootloader)”
you may start a H
0x00000000-0x00800000 : “DreamBOX (w/ bootloader)”
0x00120000-0x00600000 : "DreamBOX Squager] wait for xt/p
usb.c: new USB bus registered, assigned bus number 1cache entry 33294a6b ..
hub.c: USB hub found
hub.c: 2 ports detectedait for clock updatey 2
Initializing USB Mass Storage driver…
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
IBM IIC driver v2.0
ibm-iic: using compatibility value for OPB freq, fix your board specific setup
i2c-dev.o: Registered ‘IBM IIC’ as minor 0
i2c-core.o: adapter IBM IIC registered as adapter 0.
ibm-iic0: using standard (100 kHz) mode
i2c-dev.o: Registered ‘IBM IIC’ as minor 1
i2c-core.o: adapter IBM IIC registered as adapter 1.
ibm-iic1: using standard (100 kHz) mode
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (cramfs filesystem) readonly.
mount_devfs_fs(): unable to mount devfs, err: -2
Freeing unused kernel memory: 92k init
Warning: unable to open an initial console.
Kernel panic: No init found. Try passing init= option to kernel.
<0>Rebooting in 180 seconds..
wie weet hier raad mee ?
