OSCAM 1.20-unstable_svn build #7365 met Tvv op vusolo2
Ben al 2 dagen aan het proberen deze draaiende te krijgen kaart/client word al herkend = ok
maar krijg nog geen licht hier m’n logfile gebruikt openpli3.0 als image
2013/03/21 11:12:19 5B36B8 r lower [internal] SA: ########
2013/03/21 11:12:19 5B36B8 r lower [internal] no PBM for provider 1
2013/03/21 11:12:19 5B36B8 r lower [internal] provider 2: 006C, valid: 1, name: TV VLAANDEREN, expiry date: 2013/05/15
2013/03/21 11:12:19 5B36B8 r lower [internal] PBM for provider 2: c200000000000000
2013/03/21 11:12:19 5B36B8 r lower [internal] providers: 2 (0000,006C)
2013/03/21 11:12:19 5B36B8 r lower [internal] parental locked
2013/03/21 11:12:19 5B36B8 r lower [internal] ready for requests
2013/03/21 11:12:19 5B36B8 r lower [internal] found cardsystem seca
2013/03/21 11:12:19 5B36B8 r lower [seca] provider 1: 0000, valid: 1, name: MANAGMENT, expiry date: 2013/05/14
2013/03/21 11:12:19 5B36B8 r lower [seca] SA: ########
2013/03/21 11:12:19 5B36B8 r lower [seca] no PBM for provider 1
2013/03/21 11:12:19 5B36B8 r lower [seca] provider 2: 006C, valid: 1, name: TV VLAANDEREN, expiry date: 2013/05/15
2013/03/21 11:12:19 5B36B8 r lower [seca] PBM for provider 2: c200000000000000
2013/03/21 11:12:22 0 s init for all local cards done
2013/03/21 11:12:22 0 s anti cascading disabled
2013/03/21 11:12:22 77000468 c plain dvbapi-client granted (dvbapiau, au=on (1 reader))
2013/03/21 11:12:22 77000468 c dvbapi: Warning: line containing rum. in oscam.dvbapi not recognized, ignoring line
2013/03/21 11:12:22 77000468 c dvbapi: Warning: line containing in oscam.dvbapi not recognized, ignoring line
2013/03/21 11:12:22 0 — Skipped 6 duplicated log lines —
2013/03/21 11:12:22 77000468 c dvbapi: 173 entries read from oscam.dvbapi
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 0] CAID: 1817 ECM_PID: 070C PROVID: 00006A
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 1] CAID: 1818 ECM_PID: 0720 PROVID: 00006C
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 2] CAID: 1819 ECM_PID: 0734 PROVID: 00006D
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 3] CAID: 0100 ECM_PID: 070C PROVID: 00006A
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 4] CAID: 0100 ECM_PID: 0720 PROVID: 00006C
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 5] CAID: 0100 ECM_PID: 0734 PROVID: 00006D
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 0590 PROVID: 042500
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 05A4 PROVID: 042500
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 8] CAID: 0100 ECM_PID: 070C PROVID: 00006A
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 9] CAID: 0100 ECM_PID: 0734 PROVID: 00006D
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 10] CAID: 0500 ECM_PID: 0590 PROVID: 042500
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 05A4 PROVID: 042500
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 070C PROVID: 00006A
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 0734 PROVID: 00006D
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 14] CAID: 0500 ECM_PID: 0590 PROVID: 042500
2013/03/21 11:12:24 77000468 c dvbapi: [ADD PID 15] CAID: 0500 ECM_PID: 05A4 PROVID: 042500
2013/03/21 11:12:24 77000468 c dvbapi: new program number: 5221 (0000:5221 unknown) [pmt_list_management 3]
2013/03/21 11:12:24 77000468 c dvbapiau (0000&000000/0000/5221/64:611B): rejected caid (1 ms) (0/0/0/0) (CAID not supported or found)
2013/03/21 11:12:36 77000468 c dvbapiau (0500&042500/0000/5221/43:E50D): rejected group (1 ms) (0/0/0/0) (no matching reader)
Wat is hier fout?
Alvast bedankt
Wat is hier fout?
Alvast bedankt
ik zie al een fout in de oscam.dvbapi daar zit iets niet goed maak deze maar eens leeg
is leeggemaakt en heb er enkel
P: 0100:00006C:: ingezet en direct licht verdorie seg en daar 2 dagen mee bezig moeten zijn wist da ik ni ver meer zat bedankt Daan
Ik maak hier zelf totaal geen gebruik van dat dvbapi file.
De regel die je er nu in hebt staan, heeft geen nut als je er verder geen manipulatie met andere regels op uitvoert.
Dus je kunt dat file net zo goed weghalen.
Een recent topic wat een beetje diepgang heeft over dat dvbapi file zou ik je aanraden om eens rustig door te lezen
Heb hem eruit gehaald en idd zonder blijft hij ook licht geven, is allemaal nieuw voor me na 8jaar cccam gebruiker te zijn zou nu nog enkel m’n F/C connecties moeten integreren dit zal me ook weer enkele dagen inbeslag nemen.
Grts
Dat stukje log gaf de fout aan.
Er stond dus in oscam.dvbapi regels die niet klopte. Dat heb je nu opgelost.
oscam.dvbapi is handig indien je 2 of meer kaarten hebt, daarbij moeten de kaarten wel verschillen. Bijvoorbeeld een cdnl en tvv kaart of ziggo 0604 en 0602 kaart.
Indien je 1 kaart heb mag je hem gerust leeg laten.
ok thx weeral iets bijgeleerd vandaag en voor de rest is ook alles inorde gekomen
grts
