Nieuwe firmware topfield 5000, 5 december 2003
Software of TF5000PVR (DEC 05 2003)
  1. IRD status of Dec 06 2003 version
(1) System ID : 406
(2) Device Version : v5.2.40
(3) Application Version : TF-NPC 5.10.56
(4) Last Update : Dec 05 2003
  1. Improvements of this version
(1) The problem of EPG is fixed
(2) The output level of YUV is modified.
(3) The CI Menu is improved.
(4) The size of MP3 file is not limited.
(5) Recording during can be set by 1 minute.
(6) There was a problem in recorded file copy from PVR to PC in
Astra(11837/27500/H). It is fixed.
(7) The problem in cutting scrambled file is fixed.
(8) The RF output was black and white in Super Video Mode. It is fixed.
(9) The default setting in search menu is changed from Network Search
On to Network Search Off
(10) “CAM initializing” message is displayed too much. It is modified.
(11) The Canal+ EPG is supported.
(12) The problem in the large HDD is fixed.
(13) The Subtile is modified.
(14) Bookmarks for files in subfolder can be set.
(15) The new bug that PVR can not descramble during recording
at ver 5.10.44 is fixed.
(16) The problem at reservation in EPG is fixed.
(17) The CAM Initializing problem at a specific CAM is fixed.
(18) DVB Subtitle is added.
(19) The improper name at reservation by EPG is fixed.
(20) Automatic Tuner selection by EPG reservation is added.
(21) Timeshift is not stop while recording starts with the other.
(22) PIP channel number was not updated. It is fixed.
(23) Duplicate name for delayed recording is permitted from this version.
(24) Multifeed problem is fixed.
(25) Subtitle text was not deleted when the channel was changed. It is fixed.
(26) Wrong favorite selection problem is fixed.
(27) Hang up rarely while rewinding is fixed
(28) File system of HDD is changed.
(The old HDD is converted automatically by updating the firmware.)
Te downloaden bij topfield korea.
Heb je 'm er in zitten Happy?
Alles kits?
Fijn weekend
Ja ik heb hem erin zitten, maar ik ga nu nog niet zeggen dat ie goed is ofzo want daarvoor heb ik hem er te kort in.
Hier de directe download.
http://www.topfield.co.kr/technote/read.cgi?board=TF5000PVR&y_number=3&nnew=2
Ik ben benieuwd. Is ie ook al te downloaden via OTA?
Je kunt iig zien of de C+ EPG werkt of niet…
Hoi,
Net erin gedan en idd de epg werkt voor de rest moet ik nog ff kijken…
Maar dit is in ieder geval top.
Groeten Newbier
Die van mij is al 3 keer vast gelopen als ik het menu doorloop. Uitzetten gaat noet meer. Alleen de stekker eruit helpt..
YES, meeste bugs verdwenen met nieuwe software :+1:
Alleen zapt wel iets langzamer, of ligt dat aan mijn 3e pot bier :face_with_tongue:
Hoi,
Dat id had ik ook dat hij iets trager is met zappen.
Ook de epg werkt nog niet perfect maar het is eem begin…
Groeten Newbier
Heb sinds vanmorgen nieuwe firmware er in maar heb nu al 2 problemen; :confused: EPG (canaal+) is bij de Ned.zenders alleen een dag vooruit te bekijken.
Beeld staat steeds vast met MM 1.02 (Penta 1.10),krijg alleen weer beeld als ik de receiver uit/aan doet.
Met Aston 1.05 + org. kaart tot nu toe niet dat probleem.
Eerste probleem is bekend… is ook maar een goedheid van Topfield dat men probeert in de soft de mediaguard applicatie te inplanteren. Ze zijn daar nog aardig mee aan het testen dus in een volgende versie zal dit zeker verholpen dan wel verbeterd zijn.
Tweede probleem kan je zelf makkelijk verhelpen. Al eerder is duidelijk gemaakt dat men bij een fabriek als Topfield zeker niet alle MMachtige modules met funkaartjes op goede werking te controleren. Het gaat hier alleen om de ondersteuning van officiele CI’s met officiele kaarten erin. Natuurlijk kijkt men daarnaast ook wel naar de MMachitige en probeert men deze zo goed mogelijk te laten werken. In jouw geval en dat was al eerder hier en ook elders te lezen kan je de problemen met 99% zekerheid voor het grootste gedeelte verhelpen door de software in de MM te downgraden naar Pentacrypt 1.05 of nog beter naar tetracrypt. Dan werkt alles weer naar behoren als het goed is.
Ik had dit probleem niet met de firmware van augustus!
In 1 woord …GEWELDIG !!!
Gisteren de nieuwe soft geladen. M’n Toppie is voorzien van MR1.053 (nu zonder kaart) en een HD van Maxtor,120Gig.
Geen opname’s meer gehad die half/half (geel/groen) waren opgenomen, Geen uitval meer op de CI indien je eventueel wat langer kijkt dan een half uur. Kortom perfect.!!!
Dan het geluid, ik heb alle soorten en merken geprobeerd/getest, ik heb nimmer zo’n geluid gehad van een opname. Bij dit model (dus 5000) is de sound vlekkeloos, geen happering, geen “knispering rondom” een stem of zo…Neen, gewoon strak en origineel.
Er blijft natuurlijk nog een wensen lijstje die Topfield volgens mij zeker nog wel zal gaan invullen.
Ik zit nog te wachten op:
* Tuner 1 en 2 en/of HD-playback ondersteuning via de nieuwste dual Aston module.
* Het kunnen schakelen tussen twee originele CI modules bijvoorbeeld Irdeto en Aston, de huidige SW laat geen CI wissel toe tenzij je de Toppie uitzet en wisselt naar een andere CI.
Met vriendelijke groet van een zeer tevreden en genietende
Dvsat
Nou heb hem hier nu 1 dag erin en moet zeggen dat het nog niet goed is, er zitten nog verschillende bugs in.
De epg van canal+ werk niet (niet goed, klopt niks van)
de audio mono bug zit er nog steed in met afspelen (is dat zo moeilijk omdat er uit te halen?)
Irdeto freecam werkt niet meer goed.
Lipsync probleem zit er nog in maar niet meer zo erg.
En deze versie is dus gewoon de beta versie van decemder die al eerder uitgebracht was.
Klagen over een beta versie is natuurlijk niet zo zinvol…
Daarom is het meestal ook een betaversie!
Stuur je op en aanmerkingen op naar de fabrikant of importeur!
@Murdock,
Het gaat hier over een officiele verse, geen Beta.
Kom nog ff terug op mezelf. Sychronisatie beeld/geluid nog niet goed.
EPG is alleen maar slechter geworden.
Markering van zenders is opgelost.
De vervelende rode balk is nu ook weg bij het "langzamere"zappen.
Vooral het synchronisatie probleem is mijn geval ( dit na 4 verschillende updatés) reden om hem terug te brengen naar de Satboer.
Waar heb je die synchronisatie problemen dan mee en dan bedoel ik met welke CI en wat voor kaart. Het zijn stuk voor stuk bugs welke opgelost moeten worden alleen kan men deze bugs slechts oplossen als men ook de goede informatie krijgt om de bug te kunnen nabootsen en dus aan de hand daarvan oplossingen kan bedenken en maken in de software. Aan synchronisatie heeft men op zich als term niets omdat men dan niet weet ik welke hoek men het moet zoeken.
Overigens zijn een hoop synchronisatie problemen te verhelpen door als het gaat om een MMachtige module terug te gaan naar tetracrypt of penta 1.05.
aston seca met org. kaart, als ik hem in de arnion 6400 druk heb ik er geen last van (1.05), valt trouwens veelal op bij sbs6, weet niet of dat nog wat uitmaakt?
Inderdaad is de EPG niet bepaald OK, maar…zaterdag was het enkel op Ned 1,2,3 maar RTL-4 was wel OK met de EPG gegevens. Ik heb niet vergeleken met een andere receiver, maar is C+ niet weer eens in gebreke met zijn EPG ??
Betreffende het geluid af HD heb ik vele testjes gedaan met voornamelijk muziek, alles van diverse zenders na opname beluistert, zelfs opnames welke 2x gelijktijdig etc.
Niet 1 was mono of minder stereo, alles voortreffelijk stereo gelijk origineel. Nog even vergeleken met oude HD opname van de vorige SW versie, inderdaad mono.
Conclusie, bij mij nu “hardstikke” mooi stereo.
Ook nog even optisch dezelfde testjes gemaakt en inderdaad geen mono vanaf HD maar ook duidelijk STEREO.
Irdeto Freecam werkt bij mij identiek als bij een 4000 ofwel goed, misschien kun je melden wat je bedoeld met niet meer goed ???
Ik ben destijds altijd bezig geweest over de Humax-5400 die niet lekker lipsync zou zijn, maar deze 5000 heeft geen problemen met de synchroniteit.
Tot slot, de combinatie MR1.053/TF5000 gaf tot voor gisteren met de oude SW geen ORF, nu met de vernieuwde SW weer uitstekend ORF (nog steeds dezelfe MR)
Met vr groet,
Dvsat
