Nu het storend begint te worden en ik al heb geprobeerd om een andere versie van OScam te installeren en zelfs een andere image blijven de onregelmatige haperingen terugkomen.
Wil iemand kijken in de log hieronder of er iets vreemds gebeurd? In deze log is er 3 keer een hapering geweest.
2024/11/16 16:38:38 00000000 s (main) Host name = dm920
2024/11/16 16:38:38 00000000 s (main) Release = 3.14-1.17-dm920
2024/11/16 16:38:38 00000000 s (main) Version = #2 SMP Fri Feb 9 16:42:57 UTC 2018
2024/11/16 16:38:38 00000000 s (main) Machine = armv7l
2024/11/16 16:38:38 00000000 s (main) Stb model = dm920
2024/11/16 16:38:38 00000000 s (main) creating pidfile /tmp/oscam.pid with pid 14191
2024/11/16 16:38:38 00000000 s (config) userdb reloaded: 2 accounts loaded, 0 expired, 0 disabled
2024/11/16 16:38:38 00000000 s (main) signal handling initialized
2024/11/16 16:38:38 00000000 s (config) 10 provid’s loaded
2024/11/16 16:38:38 00000000 s (config) 164 service-id’s loaded in 1 ms
2024/11/16 16:38:38 00000000 s (net) cs378x: initialized (fd=3, port=12005)
2024/11/16 16:38:38 00000000 s (reader) lower_card_CD-NL [internal] creating thread for device /dev/sci0
2024/11/16 16:38:38 00000000 s (main) waiting for local card init
2024/11/16 16:38:38 75BAF289 r (reader) lower_card_CD-NL [internal] Dreambox dm920 found! set Internal Card-MHz = 2700
2024/11/16 16:38:38 53A25D15 h (webif) webif: decompressed 169509 bytes back into 418432 bytes
2024/11/16 16:38:38 53A25D15 h (webif) HTTP Server running. ip=:: port=83
2024/11/16 16:38:39 75BAF289 r (reader) lower_card_CD-NL [internal] card detected
2024/11/16 16:38:41 75BAF289 r (reader) lower_card_CD-NL [internal] ATR: 3B F7 11 00 01 40 96 70 70 0A 0E 6C B6 D6
2024/11/16 16:38:42 75BAF289 r (reader) lower_card_CD-NL [internal] detect seca/nagra tunneled card
2024/11/16 16:38:44 75BAF289 r (reader) lower_card_CD-NL [internal] Nagra layer found
2024/11/16 16:38:44 75BAF289 r (reader) lower_card_CD-NL [internal] Rom revision: DNASP400 RevI4G
2024/11/16 16:38:46 75BAF289 r (reader) lower_card_CD-NL [internal] type: SECA, caid: 0100, serial: #########, card: Mediaguard v10.0
2024/11/16 16:38:46 75BAF289 r (reader) lower_card_CD-NL [internal] Maturity level [F]=no age limit
2024/11/16 16:38:46 75BAF289 r (reader) lower_card_CD-NL [internal] found card system seca
2024/11/16 16:38:46 75BAF289 r (reader) lower_card_CD-NL [seca] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max allotted of 1
2024/11/16 16:38:46 75BAF289 r (reader) lower_card_CD-NL [seca] Request provider 1
2024/11/16 16:38:47 75BAF289 r (reader) lower_card_CD-NL [seca] provider 1: 0000, valid: 1, name: MANAGEMENT, expiry date: 2025/01/13
2024/11/16 16:38:47 75BAF289 r (reader) lower_card_CD-NL [seca] SA: ########
2024/11/16 16:38:47 75BAF289 r (reader) lower_card_CD-NL [seca] PBM for provider 1: 799008001c000
2024/11/16 16:38:47 75BAF289 r (reader) lower_card_CD-NL [seca] Request provider 2
2024/11/16 16:38:47 75BAF289 r (reader) lower_card_CD-NL [seca] provider 2: 006A, valid: 1, name: CANAL DIGITAAL, expiry date: 2025/01/09
2024/11/16 16:38:47 75BAF289 r (reader) lower_card_CD-NL [seca] PBM for provider 2: a200000000000000
2024/11/16 16:38:47 00000000 s (main) init for all local cards done
2024/11/16 16:38:47 00000000 s (emmcache) loaded 99 emmcache records from /etc/tuxbox/config/oscam/oscam.emmcache in 1 ms
2024/11/16 16:38:47 00000000 s (emmcache) loaded 103 emmstat records from /etc/tuxbox/config/oscam/oscam.emmstat in 1 ms
2024/11/16 16:38:47 00000000 s (gbox) local gbox failed init
2024/11/16 16:38:47 0EC2F70A c (client) plain dvbapi-client granted (dvbapiau, au=auto (8 reader))
2024/11/16 16:38:47 0EC2F70A c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam/oscam.ccache
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum number of filters is 64 (oscam limit is 64)
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 8
2024/11/16 16:38:47 0EC2F70A c (dvbapi) PMT mode 6: Connecting to enigma CA PMT listen socket…
2024/11/16 16:38:47 0EC2F70A c (dvbapi) PMT mode 6: Successfully connected to CA PMT server (fd 10)
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1817 ECM_PID: 0727 PROVID: 00006A
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1818 ECM_PID: 078B PROVID: 00006C
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 ecmpid 2 CAID: 181D ECM_PID: 1023 PROVID: 000000
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0500 ECM_PID: 0C59 PROVID: 051900
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0100 ECM_PID: 0727 PROVID: 00006A PBM: FFF800000000000 DATE: 16-11-2024
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 ecmpid 5 CAID: 0100 ECM_PID: 078B PROVID: 00006C PBM: FFF800000000000 DATE: 16-11-2024
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 found 6 ECM pids and 2 STREAM pids in CA PMT
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 4
2024/11/16 16:38:47 0EC2F70A c (dvbapi) Demuxer 0 trying to descramble PID 4 CAID 0100 PROVID 00006A ECMPID 0727 ANY CHID PMTPID 0AAB VPID 0213
2024/11/16 16:38:48 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:37E9CDD72BE2F76C1F76F75678EFAF96): found (312 ms) by lower_card_CD-NL
2024/11/16 16:38:49 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:12325C56E99D63A7245048A5F1B3D840): found (312 ms) by lower_card_CD-NL
2024/11/16 16:38:59 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:A8A9A49587F28A11C09CA529EEB8E7F9): found (312 ms) by lower_card_CD-NL
2024/11/16 16:39:09 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:DC5F0111391C1742DAF58100B9C7EFA0): found (316 ms) by lower_card_CD-NL
2024/11/16 16:39:19 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:2BFD466145035FC729EA41686DC71C82): found (311 ms) by lower_card_CD-NL
2024/11/16 16:39:29 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:BD6AC4C12410234888BCD39ACBF8EF5D): found (312 ms) by lower_card_CD-NL
2024/11/16 16:39:39 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:2CFD765A9BDC13AD35674CE2C3B0E7FF): found (312 ms) by lower_card_CD-NL
2024/11/16 16:39:40 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:39:49 0EC2F70A c (-) – Skipped 3 duplicated log lines –
2024/11/16 16:39:49 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:0D53387D338CFA647F5FDA02930DEA3B): found (492 ms) by lower_card_CD-NL
2024/11/16 16:39:52 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:39:59 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:39:59 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:257DE8837139F5A62028CA05114D5372): found (312 ms) by lower_card_CD-NL
2024/11/16 16:40:00 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (284 ms)
2024/11/16 16:40:01 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:09 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:40:09 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:B189458FAA1147DD01ECD1312973DF03): found (312 ms) by lower_card_CD-NL
2024/11/16 16:40:10 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:19 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:40:19 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:AC26C2527C0F7ADACDE865610293B97D): found (312 ms) by lower_card_CD-NL
2024/11/16 16:40:20 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:21 75BAF289 r (reader) lower_card_CD-NL [seca] Request provider 1
2024/11/16 16:40:21 75BAF289 r (reader) lower_card_CD-NL [seca] provider 1: 0000, valid: 1, name: MANAGEMENT, expiry date: 2025/01/13
2024/11/16 16:40:21 75BAF289 r (reader) lower_card_CD-NL [seca] SA: ########
2024/11/16 16:40:21 75BAF289 r (reader) lower_card_CD-NL [seca] PBM for provider 1: 799008001c000
2024/11/16 16:40:21 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=shared, len=119 (hex: 0x77), cnt=1: written (407 ms)
2024/11/16 16:40:21 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:29 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:40:29 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:A8BDE9B226DF836E043C9812A8B68AD5): found (316 ms) by lower_card_CD-NL
2024/11/16 16:40:32 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:37 75BAF289 r (-) – Skipped 1 duplicated log lines –
2024/11/16 16:40:37 75BAF289 r (reader) lower_card_CD-NL [seca] Request provider 1
2024/11/16 16:40:37 75BAF289 r (reader) lower_card_CD-NL [seca] provider 1: 0000, valid: 1, name: MANAGEMENT, expiry date: 2025/01/13
2024/11/16 16:40:37 75BAF289 r (reader) lower_card_CD-NL [seca] SA: ########
2024/11/16 16:40:37 75BAF289 r (reader) lower_card_CD-NL [seca] PBM for provider 1: 799008001c000
2024/11/16 16:40:37 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=shared, len=119 (hex: 0x77), cnt=2: written (406 ms)
2024/11/16 16:40:37 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:39 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:2E974668FD915D8C308BE6AE2C713951): found (312 ms) by lower_card_CD-NL
2024/11/16 16:40:40 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:49 0EC2F70A c (-) – Skipped 3 duplicated log lines –
2024/11/16 16:40:49 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:FA3501D34E27FF2FA14AB9A6D7BD6A91): found (312 ms) by lower_card_CD-NL
2024/11/16 16:40:50 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:40:59 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:40:59 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:62E306819ED24A9547205E744485E2A3): found (312 ms) by lower_card_CD-NL
2024/11/16 16:41:00 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:41:01 75BAF289 r (reader) lower_card_CD-NL [seca] Request provider 2
2024/11/16 16:41:01 75BAF289 r (reader) lower_card_CD-NL [seca] provider 2: 006A, valid: 1, name: CANAL DIGITAAL, expiry date: 2025/01/09
2024/11/16 16:41:01 75BAF289 r (reader) lower_card_CD-NL [seca] SA: ########
2024/11/16 16:41:01 75BAF289 r (reader) lower_card_CD-NL [seca] PBM for provider 2: a200000000000000
2024/11/16 16:41:01 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=shared, len=119 (hex: 0x77), cnt=1: written (412 ms)
2024/11/16 16:41:02 75BAF289 r (reader) lower_card_CD-NL [seca] PBM for provider 2: a200000000000000
2024/11/16 16:41:02 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=shared, len=119 (hex: 0x77), cnt=2: written (411 ms)
2024/11/16 16:41:02 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:41:09 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:41:09 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:0FCAAF20054285FC08E1C59D627D418E): found (316 ms) by lower_card_CD-NL
2024/11/16 16:41:12 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:41:19 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:41:19 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:ADB1EF277AA73F06153AE3BB8E9921DE): found (312 ms) by lower_card_CD-NL
2024/11/16 16:41:20 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:41:29 0EC2F70A c (-) – Skipped 3 duplicated log lines –
2024/11/16 16:41:29 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:EF07E4E1916220AFF817922D277721D7): found (404 ms) by lower_card_CD-NL
2024/11/16 16:41:32 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:41:44 0EC2F70A c (-) – Skipped 2 duplicated log lines –
2024/11/16 16:41:44 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:26E303C27711393C72ED320B31326828): timeout (5000 ms) by lower_card_CD-NL
2024/11/16 16:41:49 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:26E303C27711393C72ED320B31326828): timeout (5001 ms) by lower_card_CD-NL
2024/11/16 16:41:49 0EC2F70A c (dvbapi) Demuxer 0 restarting decoding requests after 0 ms with 2 enabled and 4 disabled ecmpids!
2024/11/16 16:41:49 0EC2F70A c (dvbapi) Demuxer 0 trying to descramble PID 4 CAID 0100 PROVID 00006A ECMPID 0727 ANY CHID PMTPID 0AAB VPID 0213
2024/11/16 16:41:51 75BAF289 r (reader) lower_card_CD-NL [seca] Warning: needed try nr 2, next ECM has some delay
2024/11/16 16:41:51 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:41:52 0EC2F70A c (-) – Skipped 1 duplicated log lines –
2024/11/16 16:41:52 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:FD56B439F609087A3A241C0E69D0402A): found (2557 ms) by lower_card_CD-NL
2024/11/16 16:41:52 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:FD56B439F609087A3A241C0E69D0402A): cache2 (3095 ms) by lower_card_CD-NL
2024/11/16 16:41:53 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:41:56 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (286 ms)
2024/11/16 16:41:57 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (284 ms)
2024/11/16 16:41:59 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:CAA47D9CE6B4ED8AC454A01468A57EE2): found (312 ms) by lower_card_CD-NL
2024/11/16 16:42:00 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (286 ms)
2024/11/16 16:42:02 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:42:06 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:42:08 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (304 ms)
2024/11/16 16:42:09 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (285 ms)
2024/11/16 16:42:09 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:393596C1C1DF8F39EABF09C7262F1A6C): found (320 ms) by lower_card_CD-NL
2024/11/16 16:42:12 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (296 ms)
2024/11/16 16:42:13 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:42:19 0EC2F70A c (-) – Skipped 1 duplicated log lines –
2024/11/16 16:42:19 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:534D38AAD4D1CC96128780AFCE720199): found (312 ms) by lower_card_CD-NL
2024/11/16 16:42:20 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (286 ms)
2024/11/16 16:42:24 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:42:27 75BAF289 r (-) – Skipped 1 duplicated log lines –
2024/11/16 16:42:27 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (284 ms)
2024/11/16 16:42:29 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:42:29 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:FCD1C6EAA67A353032C0EF438125609F): found (316 ms) by lower_card_CD-NL
2024/11/16 16:42:32 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:42:33 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (284 ms)
2024/11/16 16:42:36 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:42:37 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (282 ms)
2024/11/16 16:42:39 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:E86F74E300194DC805B2621A1E4F5CF1): found (312 ms) by lower_card_CD-NL
2024/11/16 16:42:40 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (285 ms)
2024/11/16 16:42:41 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (282 ms)
2024/11/16 16:42:44 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:42:49 0EC2F70A c (-) – Skipped 1 duplicated log lines –
2024/11/16 16:42:49 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:31F8AE40751DA58782ACDCEF4B77408E): found (312 ms) by lower_card_CD-NL
2024/11/16 16:42:50 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:42:56 75BAF289 r (-) – Skipped 1 duplicated log lines –
2024/11/16 16:42:56 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:42:59 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:C2FEE6BC688D9E74DBD40D3F80A437D4): found (312 ms) by lower_card_CD-NL
2024/11/16 16:43:00 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:43:01 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:04 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=3: written (284 ms)
2024/11/16 16:43:05 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:08 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:43:09 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:808EC27CBE6B99FCF8646C1831D0CA2C): found (316 ms) by lower_card_CD-NL
2024/11/16 16:43:12 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:43:13 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:16 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:43:17 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:19 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:59B95F1FC2227EDB645A586CAA55AAE2): found (312 ms) by lower_card_CD-NL
2024/11/16 16:43:20 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:43:25 75BAF289 r (-) – Skipped 1 duplicated log lines –
2024/11/16 16:43:25 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:28 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:43:29 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:29 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:2357D9BF9E00827D7DDB094A9EF149B7): found (373 ms) by lower_card_CD-NL
2024/11/16 16:43:32 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:43:37 75BAF289 r (-) – Skipped 1 duplicated log lines –
2024/11/16 16:43:37 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:44 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:A219A25CA5730FD3CE5F82C87AE9B311): timeout (5000 ms) by lower_card_CD-NL
2024/11/16 16:43:49 0EC2F70A c (-) – Skipped 1 duplicated log lines –
2024/11/16 16:43:49 0EC2F70A c (dvbapi) Demuxer 0 trying to descramble PID 5 CAID 0100 PROVID 00006C ECMPID 078B ANY CHID PMTPID 0AAB VPID 0213
2024/11/16 16:43:50 0EC2F70A c (ecm) dvbapiau (0100@00006C/5C00/528B/64:CC682AE3385A55141B48AA3D19ECC62F): rejected group (0 ms) (no matching reader)
2024/11/16 16:43:50 0EC2F70A c (ecm) dvbapiau (0100@00006C/5C00/528B/64:CC682AE3385A55141B48AA3D19ECC62F): rejected group (1 ms) (no matching reader)
2024/11/16 16:43:50 0EC2F70A c (dvbapi) Demuxer 0 restarting decoding requests after 0 ms with 2 enabled and 4 disabled ecmpids!
2024/11/16 16:43:50 0EC2F70A c (dvbapi) Demuxer 0 trying to descramble PID 4 CAID 0100 PROVID 00006A ECMPID 0727 ANY CHID PMTPID 0AAB VPID 0213
2024/11/16 16:43:51 75BAF289 r (reader) lower_card_CD-NL [seca] Warning: needed try nr 2, next ECM has some delay
2024/11/16 16:43:51 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:43:52 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:9C949CC911384CC77150B6E87E57032F): found (1189 ms) by lower_card_CD-NL
2024/11/16 16:43:52 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:9C949CC911384CC77150B6E87E57032F): cache2 (2791 ms) by lower_card_CD-NL
2024/11/16 16:43:52 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:43:53 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:43:56 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:43:57 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (282 ms)
2024/11/16 16:44:04 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:E451ED02286F56435255220113B7CEB7): timeout (5000 ms) by lower_card_CD-NL
2024/11/16 16:44:09 0EC2F70A c (-) – Skipped 1 duplicated log lines –
2024/11/16 16:44:09 0EC2F70A c (dvbapi) Demuxer 0 trying to descramble PID 5 CAID 0100 PROVID 00006C ECMPID 078B ANY CHID PMTPID 0AAB VPID 0213
2024/11/16 16:44:10 0EC2F70A c (ecm) dvbapiau (0100@00006C/5C00/528B/64:671C4D82174C876DDCA385BB73A33EF9): rejected group (1 ms) (no matching reader)
2024/11/16 16:44:10 0EC2F70A c (-) – Skipped 1 duplicated log lines –
2024/11/16 16:44:10 0EC2F70A c (dvbapi) Demuxer 0 restarting decoding requests after 0 ms with 2 enabled and 4 disabled ecmpids!
2024/11/16 16:44:10 0EC2F70A c (dvbapi) Demuxer 0 trying to descramble PID 4 CAID 0100 PROVID 00006A ECMPID 0727 ANY CHID PMTPID 0AAB VPID 0213
2024/11/16 16:44:11 75BAF289 r (reader) lower_card_CD-NL [seca] Warning: needed try nr 2, next ECM has some delay
2024/11/16 16:44:11 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:44:12 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (282 ms)
2024/11/16 16:44:12 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:842A4F8D3D7B1E81B56D5DD79CCC512A): found (1958 ms) by lower_card_CD-NL
2024/11/16 16:44:12 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:44:17 75BAF289 r (-) – Skipped 1 duplicated log lines –
2024/11/16 16:44:17 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:44:19 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:6B5A807AEADF0EFB2BF275485B930AD9): found (313 ms) by lower_card_CD-NL
2024/11/16 16:44:20 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (282 ms)
2024/11/16 16:44:21 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:44:23 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:44:29 75BAF289 r (-) – Skipped 1 duplicated log lines –
2024/11/16 16:44:29 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:44:29 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:4385387405970CFCA6C362D8202DB0C9): found (347 ms) by lower_card_CD-NL
2024/11/16 16:44:32 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:44:33 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
2024/11/16 16:44:36 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (286 ms)
2024/11/16 16:44:39 0EC2F70A c (ecm) dvbapiau (0100@00006A/5C00/528B/64:365B5BF80A7DA3D0EF8C69C8C840EE6F): found (313 ms) by lower_card_CD-NL
2024/11/16 16:44:41 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (281 ms)
2024/11/16 16:44:44 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=1: written (308 ms)
2024/11/16 16:44:45 75BAF289 r (reader) lower_card_CD-NL [seca] dvbapiau emmtype=global, len=116 (hex: 0x74), cnt=2: written (281 ms)
