DM7020 Enigma2 TestImage of 090418
Hello Friends !
Here is the new version of the TestImage :-
Enigma2_2.6 of 090415 - faster enigma and possibility of using many new plugins.
For satellite, cable and includes Adenin unicable patch.
Better recording and playback with hdd (no lipsync problem now).
Some new 2.6 plugins patched for dm600pvr - more to follow.
Yuv enabled and other improvements.
Special shortcut : Button 0 -> Extra Setup
Important
The image can be installed in flash or on multiboot (suggest plugin Barry Allen).
To keep the image size down, many useful software items are not included in the image. These are available for download via Addonmanager. Before using the plugins please install at least the item “twisted”.
For the same reason - only languages “en” and “de” are included. The others will be available for download.
If installing in flash - give these telnet commands (please use cf or usb for hdd if appropriate) :
Code:
init 4 killall -9 enigma2 mv /usr/lib/enigma2/python/Plugins/Extensions /media/hddmv /usr/lib/python2.5/site-packages /media/hdd ln -sfn /media/hdd/Extensions /usr/lib/enigma2/python/Plugins/Extensions ln -sfn /media/hdd/site-packages /usr/lib/python2.5/site-packages init 3
These commands will move the folders Extensions and site-packages to /media/hdd and make symlinks in their original locations. Please check that this has happened.
All plugins in future will go to hdd, cf or usb and you have 3.6 MB available in flash.
Installing Emulators
Menu - Extra Setup - Addonmanager - download and install emulator.
Menu - Extra Setup - Emumanager - start emu. Reboot the first time.
The emulator will auto-start at future reboots.
Installing Plugins, skins, software etc
Menu - Extra Setup - Addonmanager - Download and install addon.
Menu - Extra Setup - Addonmanager - View Install log.
Manual Install
Ftp the .ipk to /tmp folder. Then :-
Menu - Extra Setup - Addonmanager - Manual install
Automount cifs and nfs
Menu - Extra Setup - Userconfig - edit mount command
Menu - Extra Setup - Mountmanager - Start
Will automount at future reboots.
Recording to hdd/cifs/nfs
Red button - choose device
Playback from hdd/cifs/nfs
Video button - choose device.
7 day epg
Based on plugin e2_loadepg. If a channel does not show epg, the reason will be given in /media/hdd/e2_loadepg.log. The main reasons are - epg not available, channel is not selected for epg, or the channel or provider name does not agree with that in lamedb. In that case please edit the channellist.conf files in folder /usr/lib/enigma2/python/DF/e2_loadepg/dl_modules.
The format for a channel in the list is - id=n,channel name[,provider name] where :-
n=0 (channel NOT selected for epg); n=1 (selected)
channel name and provider name are the names of the channel and its provider in /etc/enigma2/lamedb. The provider name can be omitted if it is same as the Default Provider at the top of the list. If no provider name in lamedb then use the word noprovider.
The epg days can be changed in the .conf files in the /dl_modules folder.
EPG Vorgehensweise (alle Dateien und Verzeichnisse liegen in
/usr/lib/enigma2/python/DF/e2_loadepg/):-
(1) In e2_loadepg.conf - providername(n) anpassen in DOWNLOAD_MODULES= bskyb (Beispiel).
(2) In bskyb.conf (Beispiel) - MAX_DAY_EPG= anpassen der Tage fürs verfügbare Epg (von 1 bis 7, für nova muss 7 eingestellt sein!).
(3) Danach auf der dreambox - Menü -> Extra Menu -> Update epg.
Dann das MenÜ verlassesn - das update des EPG kann einige Zeit dauern, endet aber mit einem
Enigma2 - Neustart.
(4) Wenn für ein Kanal (iin diesem Beispiel vom Provider bskyb) kein EPG vorhanden ist, kann man in /media/hdd/e2_loadepg.log den Grund dafür nachlesen. Die Hauptursachen hierfür sind, wenn das EPG nicht verfügbar ist, der Kanal ist nicht für das update ausgewählt, oder der
Kanal-/Providername stimmt nicht mit dem Eintrag in der lamdb überein. Für letzteres muss man die bskyb-channellist.conf (in diesem Beispiel) in /e2_loadepg/dl_modules anpassen.
Das Format für einen Eintrag in dieser *.conf ist : id=n,channel name[,provider name] wobei :-
n=0 (Kanal NICHT fürs EPG ausgewählt); n=1 (fürs EPG ausgewählt).
Kanal-/Providername sind die Namen des Kanals bzw. dessen Providers in /etc/enigma2/lamedb.
Der Providername kann ausgelassen werden, wenn er dem Default-Provider am Anfang der Liste entspricht. Wenn in der in lamedb kein Providername steht dann muss noprovider eingetragen werden.
Picon
(1) Put the Enigma2 picon folder in ‘/media/cf/’, or, ‘/media/usb/’, or (2) make a new folder
‘picon’ with selected icons and put this folder in /usr/share/enigma2/
User Scripts
ftp userscripts to /etc/scripts.
Crond
Edit by ftp the crontab file (in /etc) as usual with time and command etc. Start Crond from setup window and reboot. An example crontab is in the image which will create a folder cronresult in /etc. Crond will run after future reboots until stopped.
Inadyn
Edit the file inadyn.conf in /etc with your inadyn info e.g. usrname, password, alias. The example file is for the dyndns.org setup.
Telnet command > /usr/bin/inadyn --h for other options. Inadyn can be started and stopped from
the setup window and will run after future reboots until stopped.
Also - view inadyn.log.
pmt.tmp
The image is set to include pmt.tmp in /tmp from start. If any emu start kills it, it can be restarted from the setup window. Check pmt.tmp window.
Skins
Default Skin - Nemesis.GlassLine .
No emus or keys included.
Heeft iemand deze image al eens getest ?
Ik ben er mee bezig.Heb de image op de usb stick staan en moet zeggen dat het er wel leuk uit ziet maar loop wel tegen een paar probleempjes op.
De 7020 is een E1 box en mijn vraag is nu moet ik in deze image nu een settingslijst voor E1 of E2 zetten.Persoonlijk denk ik de laatste.Heeft iemand hier een antwoord voor?
Dank alvast voor een reaktie
volgens mij bestaat er niet zoiets als een E1 of E2 box.
Het plaatsen van je zenderlijst is gewoon afhankelijk van de aanwezige software, bij jou dus E2
Bedankt ga het eens proberen.
Na de de meeste instellingen te hebben goed gezet in het menu kan ik zeggen dat de image goed werkt in de 7020.Ook de nederlandse kanalen geven keurig licht met de kaart.
Kan hiermee weer verder mijn naam eer aandoen,dus rommelen.
Bedankt voor je plaatsing scubix.
Origineel bericht van: rommelaar
Dat klinkt dus goed, dan ga ik er ook maar eens mee aan de slag, als ik kan uitvissen hoe die BA nu precies werkt
